Hello
is it possible to enable / disable a warning if an expression overwrites an existing / predifined function or constant?
Such as c:=4 should warn you to then overwrite the Light Speed constant.
The was as seen in Mathcad 15
I assume you mean "can you do this in Prime?".
No. One of the many missing features. That's why most of us stick with Mathcad 15.
Hi Michael,
In main menu you need to select "Tools" --> "Preferences" --> tab "Warnings" --> uncheck "Show warnings on redefinitions of":
You are right. Its about Prime 3.
I miss that functions and other functions too
