I posted this question in the Mathcad community, but it applies to Creo Elements/Pro users too.
This is probably old news to some...I caught this story on msnbc, http://www.msnbc.msn.com/id/3032619//vp/42462968#42462968
It talks about the recent sale of Pringles for $2Billion and how the chip's shape is a perfect hyperbolic paraboloid.
I was wondering if any Creo Elements/Pro (formerly Pro/ENGINEER) members would be willing to recreate the Pringle or their favorite snack in Creo Elements/Pro, display their take on the hyperbolic paraboloid or share other examples of engineered food here.
For inspiration, take a look at this Ho Ho extruder, http://communities.ptc.com/docs/DOC-1347
-Dan
Vladimir,
I'm with you! Love building geometry, especially if there's a little mathematical flavor to it. Since you are a Mathcad wizard, I'm wondering which of many possible approaches you used for your model. I just swept one conic section on another and trimmed. I'm not as much of a rendering expert as you so mine aren't quite as edible.
David
Hello.
I have last five pieces of "Creo Pringles". Let your taste
Vladimir
Well done Vladimir! I swear you either have libraries of renderings or can whip up anything in minutes using Creo Elements/Pro, or both!
Vladimir,
David
Wow you even created the packaging container! A nice representation of a cylinder with a lip
Hello David - nice work.
I used the parabolic surface and warp features to create hyperbolic shape. At the end I used the feature Thickness
Vladimir
Yes, I used Thicken at the end, too. I think it's one of the strategies the folks don't use as often as they should. If you try to build such things as "solid" features directly, it's much more complicated, often impossible. Perhaps the commonest example is the wave washer so often used to illustrate a trajpar controlled Variable Section Sweep. In that case it's also best to create a Surface, then Thicken; you don't get the right geometry otherwise.
