The differential equation solve block is giving an error regarding too few initial conditions. I have 3 second order equations and 6 initial conditions. I cannot understand why there is an error??
Any assistance would be appreciated
Thanks Ross
Mathcad's error messages have always been challenging to understand. An error message in a solve block that can't be traced should usually be interpreted as, "I'm not sure what is the problem but I can't find a solution."
I never found a way to actually parse out what the issue is short of trial and error.
Fred, It amazes me how complex the code must be behind the what you see. The logic needed to investigate issues and give a meaningful error diagnosis must be just as complicated and I guess they dedicate less time to this than we would like. Thanks for your insights.
Cheers
Ross
check the definition of xb, it has a multiply between the name & the bracket
seems to be the only error - after this was corrected the sheet appears to run.
Andy
Andy,
I knew it had to be something simple. Such a powerful program but so often you get tripped up by simple syntax.The Community saves the day..........again!
Many thanks. Ross
