i have 3 questions in the attached sheet. please scroll down to the three big red arrows for the questions. it is about taking the "i" value from each vector and use it in evaluating the values. Thanks!
Since I changed the range variable to a vector you not longer need the index i, as Werner pointed out.
The parentheses is more confusing and so is the italic maths. Maybe me being fussy, but I find it hard to read and follow.
Not exactly. My remark about omitting the index was meant for the one variable which is a scalar. But of course it would be also possible to omit all indices (also on the LHS) but then I would suggest to vectorize the RHS - just to be on the safe side (its not absolutely necessary for this specific calculation as far as I remember).
I tend to second that, yes. Also I found the 8pt font in the last sheet hard to read for my old eyes. I noticed that you had set it to 10pt, too 😉
My eyes are not that old, just not very good
