Evalyating a Polynomial Graph
awibroe
Firstly, this is a feature of Mathcad I am exploring for the first time.
I am looking at a problem whereby I have a series of coordinates which I have used to plot a graph.
I now need to evaluate the graph in two ways. One I need to find what the largest value on the y value is and then the point at which the curve crosses the x axis (for the second time).
I can do this by eye and say that y is larges at ~0.52 and the curve crosses the x axis at ~84 degrees.
Is there a way to evaluate this mathematically to get a more accurate approximation?
Also can anyone tell me how I can increase the accuracy of the scales i.e. the points on the x axis of interest are currently 81 then 90. How can I show more points i.e. increments of 1 degree on the x axis?
Andy.
1 ACCEPTED SOLUTION
vlehner
(To:awibroe)
change the unit from Thetaxmax to °:
Volker
12 REPLIES 12
vlehner
(To:awibroe)
Hi Andy,
Answers see attachement.
Hope it will be helpful.
Best regards, Volker
Volker
awibroe
(To:vlehner)
Hi There,
I have Mathcad Prime 3 and it will not allow me to open the file because it is made from a later version. Is it possible to save it in a format I can open?
vlehner
(To:awibroe)
Ah! I'm working in MCP4. So lets communicate via PDF-File.
Volker
awibroe
(To:vlehner)
‌yyeah I have an acedemic copy and bought it just before 4 came out so I'm stuck with 3.
vlehner
(To:awibroe)
Klick the second number on the x-Achse and change it to e.g 5.
Mathcad takes the steps in5 steps up to 90.
see this:
Volker
awibroe
(To:vlehner)
I've looked through the PDF as I cant open the Mathcad file. I am clearly not doing something correctly as I get a different value to you?
awibroe
(To:vlehner)
Also, are the lines you have on added manually or is this something mathCad can do?
Also, is the value at which the graph crosses the x axis near 85degrees achievable in the same way?
vlehner
(To:awibroe)
You can add the Lines This way-It's not automaticly:
click into the diagramm, switch menue to "Diagramme" and choose this: horizontal and vertikal markers
you must change the Values manual.
I took the values from my solution in th solve block (copy and paste it into the diagram-Markers for x and y.
Volker
Volker
awibroe
(To:vlehner)
‌tthanks!
any idea on why the values I'm generating are not the same as yours? I think I've followed the procedure correctly?
vlehner
(To:awibroe)
Volker
awibroe
(To:vlehner)
Legendary!
Thanks for that and it seems the same approach can be taken for the second part of my question which I have done!
vlehner
(To:awibroe)
Thank you!
Volker
