Explicited expression does not match when saved to a varialble name
SOLVED
rdliquid
Granite
Hi
Say I have an expression:
Z(s):= c(s)[a(s)+b(s)]; where s is a variable
When I evaluated them, they are not the same.
Z(s)=
The results is not the same as:
c(s)[a(s)+b(s)]=
Please see attached for a better explanation. The bottom right row result is not the same as the bottom left result. Bottom right row is correct
I think it has to do with some kind of matrix errors
Rdliquid
Re: Explicited expression does not match when saved to a varialble name
Your function Z(s) is NOT dependent on "s" but on "freq". If you want it to be dependent on "s" you would have to write
EDIT: The pic showed the wrong expression - replaced it for the correct one.
8 REPLIES 8
Did you type the   [   ( and the     ] )   ?
Then there's your error. You should ONLY type those if you want to make a matrix.
This equation should be typed in as:
c(s)*(a(s)+b(s)).
Hi Luc,
Thanks, no that is just an example and I used "[" instead of "(" for easy viewing the equation. Sorry for the confusion. The attachment will clears things up as what I mean.
I think it has to do with scalar and vector quantity.
Re-attaching the file in case it did not attach the first time
Rdliquid
Hi Werner_E,
Thanks that's it and it makes sense to me now. Still trying to get comfortable with Mathcad 6
Thanks a lot!
Rdliquid
Have a follow up question on this topic,
Do you know why I can not give a variable "s" in Zin1(s)?
As you can see from below, Zin1(s) give me a unit error and yet Zin2 without variable "s" does not give me any errors? Zin1(s) should be correct since the right side of it depends on "s" right?
Thanks a lot for your helps
Rdliquid
The error message does not make sense and is misleading.
With Z.in2 you are defining a function, not an expression which you can evaluate as in Z.in2.
So simply delete the equal sign after the definition of the function.
When you define Z.in1(s), the s is the formal function argument and has nothing to do with the vector s you defined before. In the second expression in the pic I evaluate the function with the vector s as actual argument.
You could define the function using a completely different name for the formal argument and it would work the very same way. In the pic below I used sigma as formal argument name:
BTW, do you know that you can setup the sheet so that every result shows the imaginary unit as "j" and not as "i"?
Tags (1)
Hi Werner_E,
Thanks a lot for your helps. It makes sense to me now.
I should not evaluate the function Zin1(s) after I defined it on the same line. After I moved down to the next line and evaluated Zin1(s) with the "=" sign and it works!
The reported error caused a lot of confusion for me and I was looking at a different area of the problem and I was unable to figure it out.
Also I did not know that "the s is the formal function argument and has nothing to do with the vector s you defined before". Thanks for that information as well
Not sure about the sheet set up but I am comfortable with using "i" as an imaginary number since school and just do not want to change.
Thanks again,
Rdliquid
If you are happy with "i" thats OK. I just thought to mention that you can change it to "j" throughout as its usual in electro techniques. I also noticed that you used "j" yourself when you defined s or Z(s), etc.
