Exploring Mathcad Programming (to do with units)
RWickrama
I need to get around the part of following programming where I need the variable to assign units (seconds in this example). It is not going through.
I request someone help me:  Thanks a lot
LucMeekes
23-Emerald I
(To:RWickrama)
You may consider using this to create your array:
Result:
RWickrama
(To:RWickrama)
LucMeekes
23-Emerald I
(To:RWickrama)
The element of xx with index 2 never gets a value, so when i=3, an error occurs when trying to access that element.
LucMeekes
23-Emerald I
(To:RWickrama)
You cannot attach units to a variable that you use to index (point at) elements of an array.
If you want the array elements to have units, attach the unit to the elements, or attach the unit to the array at once in the return statement.
LucMeekes
23-Emerald I
(To:RWickrama)
Result:
RWickrama
(To:LucMeekes)
Thanks. It is a help to improve my skills. I also got round s follows.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
