Export data from mathcad to Creo notebook(earlier layout)
Highlighted
Re: Export data from mathcad to Creo notebook(earlier layout)
Yes,
Layout earlier , but currently its named NOTEBOOK in creo2.0
Exactly, by sharing it in notebook makes design less prone to failure and all parameters are defined at one place only that is notebook..
What happens is , if suppose this notebook is not present in working directory or even deleted , values assigned through notebook are retained and editable.
But , its not drawing sheet.
Instead ptc has said , notebook is meant for use from scratch design.Mine is scratch design and i want these values to pass to notebook.
Hope its possible.
If not, cant any PTC representative guide me through this
Thank you for your time VladmirinN.
Awaiting your reply.
Highlighted
The Mathcad/Prime analysis has to work with 3D part/assembly.
Highlighted
correct it has to work with 3d part.But its neither a 3d part nor an assembly.
If you use creo, please check notebook when you press new ; or if you use pro e wf5, check layout.
Thank you,
Vinit Kothari
Highlighted
Simplified Logic Inc specializes in bi-directional Excel to Creo or Creo to Excel data transfer this with an application called Nitro-CELL.  Please see this Website: Simplified Logic, Inc. and YouTube Channel:  Simplified Logic, Inc. - YouTube
