Extract Matrix by Column and Raw command
SPRstructur
Dear all
I try to extract matrices by Column and Raw Input as pic attachment.
please help me
thank you.
Here is one possible approach:
MC15 sheet attached
MC15 sheet attached
SPRstructur
(To:Werner_E)
Many thank
It work well after I convert to Prime
So mark it solved!!
@SPRstructur wrote:
Many thank
Its always a good idea, when asking a question, to attach the worksheet and also mention if you are using real Mathcad or just Prime and also the version of Mathcad or Prime you are using. This is especially essential when using Prime as all versions of Prime refuse to read worksheets created with newer versions and PTC provides no way to convert Prime worksheets.
If nothing is mentioned in a question, my answers usually will be using real Mathcad (MC 15 at the time being) 😉
