Greetings to all, my problem is as follows:
Having a main table, I require to extract certain values in the same to form a new matrix only data of interest. As a picture is worth a thousand words, the following figure try to explain what I try to do:
I have tried to get it using programming, but as I am new to using Mathcad I think I have tangled more and I get an error:
Hope you can help me, thank you very much for the help
Can you explain a little more about what each function does. Maybe we can achieve what you want much simpler.
I guess the attached should do what you try to achieve.
Its just a quick hack and quite inefficient. But given that your table has just 150 rows this should not matter.
Here is an addendum. I have added two different ways to get your Componentes vector with less effort.
Thank you very much Werner, is just what you wanted to do but solve my problem, your answer has taught me a lot.
