FEM: Variable Section: Fixed End Moments
Highlighted
Adding those for Tee, WF and Box section
6 REPLIES 6
Highlighted
I think this was the one it had no drawings. Now must have.
Highlighted
I attach below the pipe, composite on double tee and composite box cases
Highlighted
Well, the last file if shown to be repeated with (1) is repeated and needs not to be copied. This is because I thought to have fixed end moments for composite on box but I haven't (so I had to post a fake repeated file); since although I have stiffnesses for composite on box I haven't run them to end of the sheet we will finish this shape maybe tomorrow.
So Steve (administrator of site) you can erase the last .mcd uploaded in this group per repeated.
Highlighted
Today FEMs for variable section type concrete deck on (steel) box section. Note also that yesterday there were two files repeated unneeded to be downloaded.
Highlighted
These are the same for a Bridge section. Local stiffnesses I couldn't do today. When finished I'll post them.
Highlighted
These are those for rectangular section "Tier 1 and 2", with secondary input suppressed to avoid potential mis-correspondences
