Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
On 6/13/2009 12:27:18 AM, jmG wrote: >A very short knowledge base >refresher, most probably very >useful. >Saved Mathcad version 8. > >jmG _____________________________
