Failed to connect. Link may be broken
llandbø
Newbie
Hello.
This Error message pops up once I scroll down to a certain excel table in my work sheet. An internal error message follows and Mathcad shut down. The table has not been an issue previous to now, but apparently there is a broken link. The main problem is that I have no way to delete this table as the error stops the program from working at once the table is shown. Any suggestions?
Re: Failed to connect. Link may be broken
Try turning off automatic calculation.  It won't solve your broken link, but it might let you scroll down to delete the table.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
