Failure installing MathCAD 15 M050, license protocol server error CR must be followed by LF
SOLVED
Visitor
Installation; MathCad 15 M050 can't get on-line license; Unexpected Error The server committed a protocol violation. Section=ResponseHader Detail=CR must be followed by LF.
Re: Failure installing MathCAD 15 M050, license protocol server error CR must be followed by LF
Hi @BobAllanNCL,
I believe you are having trial license file for Mathcad prime 6.0. You may try to run the license wizard and point Mathcad 15 application to the existing trial license file available with you.
Vipul
Hi @BobAllanNCL,
Vipul
