Fibonacci Sequence
Fibonacci Sequence
Does anyone out there know how to create a matrix to solve for b1, b2 and ultimately f(n). I believe I'm on the correct path.
6 REPLIES 6
Fibonacci Sequence
Fibonacci Sequence
Hello Bonnie, Thank you for the file. Unfortunately, I have MC8 and am unable to open the file because of the version difference. If it isn't too much to ask, could you create a folder called 'fibonacci', then in MC save the worksheet as html to that folder and zip it with winzip and e-mail it to me? It's a lot to ask and I understand if you can't take the time. Thanks for your help all the same.
Trenton
Fibonacci Sequence
Hi Bonnie.
There is a closed formula for the nth term in a Fibonachi series.I don't remember but if you are interested I can find it.
israels@avx.co.il
Fibonacci Sequence
Here is a Mathcad 8 version of my file, which includes the closed-form expression for f_n.
Fibonacci Sequence
Thank you very much for your help. And you're correct about my not knowing how to use MC or about infinit sequences. I'm just learning to do/use both. Thank you for your assistance.
Trenton
Fibonacci Sequence
Man can calculate Fibonacci number (single and "fine", n can be negative) with recurtion and reccurently
V Ochkov
http://twt.mpei.ac.ru/ochkov
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
