File Type Not Supported
SOLVED
GS_9897438
Visitor
I crashed MTC Prime 6 and the saved file is not able to be opened. The file is 1.3MB so I think the work should be in there. If someone could help restore the file, I'd greatly appreciate it.
Re: File Type Not Supported
Here you go.
Here you go.
Thank you so much!
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
