File corrupted
alanmardan
1-Newbie
File corrupted
Hello all,
I am facing a proble with a calc i have worked on for three days. Unfortunately mathcad does not open it and tells me file is corrupted.
Can any one help me please because i cant spen 3 days to do it again.
I have uploaded the file also if someone can check it for me. Thanks
Regards
Alan
1 ACCEPTED SOLUTION
StuartBruff
23-Emerald II
(To:RichardJ)
Richard Jackson wrote:
See this thread:
http://communities.ptc.com/message/91125
You can use Stuart's recovery worksheet to get almost everything back.
Or you can use Stuart to get some of it back!
7 REPLIES 7
RichardJ
(To:alanmardan)
See this thread:
StuartBruff
23-Emerald II
(To:RichardJ)
See this thread:
Thank you very much for the help. I can open it now from the attached file from stuart. this was very kind of you
regards
StuartBruff
23-Emerald II
(To:RichardJ)
See this thread:
I'm sure I've suggested that this is a standard feature. I vaguely remember trying to automate the process by getting a component to open the file and run it until a 'working' version was retrieved, but it didnae work for some reason I couldn't fathom. I would hope PTC should be able to do something similar, except better.
Stuart
RichardJ
(To:StuartBruff)
Mathcad should just do it automatically when you open the file. It knows which region is corrupted, so it would be simple for it to delete that region, add a flag in the worksheet at the correct location, and then load everything else!
StuartBruff
23-Emerald II
(To:RichardJ)
Agreed.
Thank you veru much to all, i have managed to open it again thanks to an attached file by stuart.
regards
