See the attached file.
Thickness range = 20,22,24,26,28,30 mm
Find Function is not evaluating this kind of matrix definition for thickness.
For Variable Thickness (range), i want Stress and Pcr
How to use find function with varialbles (range/array)
Thanks in advance
Prabhakaran
(Mathcad 14.0)
You can make the answer to the solve block into a function
