Find function is not working
VL_9112595
3-Visitor
I am trying to calculate the following equation for a project that i have.
Nor the find function or the root function doesn't give me the result.
I am currently using the Mathcad Prime vers 7.0.
What can i do?
Thank you!
1 ACCEPTED SOLUTION
LucMeekes
(To:VL_9112595)
Here is an example with the root() function
3 REPLIES 3
LucMeekes
(To:VL_9112595)
What can you do?
1. Attach the Prime worksheet file, not just a picture.
2. Realise that you have defined Ha, and then want to find it, while Clt and Ho are not defined.
3. Use a solve block the way it should be used in Prime. (Look it up in the help). A solve block in Prime is different from a solve block in (real) Mathcad (15 and before).
Sorry, forgot to add the file.
Here it is.
I have both of the values defined above.
LucMeekes
(To:VL_9112595)
