Find multiple solution from given and find function
SOLVED
Level 7
Hello there,
I have a problem to get multiple answers from this equation,
 kindly refer attached file for the problem. thanks in advanced
1 ACCEPTED SOLUTION
Re: Find multiple solution from given and find function
The attached sheet should help!
Be aware of the differences between ranges and vectors!
P.S.: I just realize to my pleasure that the browser spell checker is now enabled even in rich text mode! Hooray!
7 REPLIES 7
unfortunately I cant upload the file, it said
'The contents of the attachment doesn't match its file type.'
Hi!
before uploading, you must unfortunately zip your file.
This forumsoftware is a bit touchy...
Volker
thanks for your information vlehner
There are a lot of solutions (about 490).
What do you intend to do?
with 0.214<x<0.704 we have complex F.
Volker
Highlighted
 Hooray! Guys, I really appreciate your time and effort, and thanks to WernerExinger, you are the best
