FlexNet license over a DirectAccess VPN.
ChristianJakobs
3-Visitor
Hi all.
For Mathcad Prime, a certified Windows 10 version has been available for some time, and for Mathcad 15 a Windows 10 certified version has just been released, perfect.
But unfortunately none of the two will be able to fetch a FlexNet (floating) license over the 'new' Windows 10 DirectAcces VPN (IPV6). We are currently using the Citrix VPN for our Windows 7 platform where the FlexNet licensing works ok.
On the Windows 10 platform DirectAccess will be replacing the Citrix VPN.
Does anyone know of any kind of solution, and hopefully a new release for Mathcad (Prime) will in the near future be able to fetch a floating license over the DirectAccess VPN connection?
Regards Christian
You can use the "Case Logger" tool on PTC's eSupport portal to open technical support case for your question: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/log
Hi!
have you found a solution? we have the same problem with Creo.
br Bernhard
