Foor Loop
SOLVED
Amethyst
Foor Loop
Hi all.
Why am I seeing all the extra rows  of Zeros?
I just want to see 4 to 8
Thanks for the help.
Tags (1)
Re: Foor Loop
Indexes into matrices start at zero
9 REPLIES 9
Re: Foor Loop
What version are you using?
You need to include the file.
Re: Foor Loop
We see neither zeros nor 4's or 8's!
Obviously you forgot to add a picture, or, preferably, your worksheet.
My crystal ball thinks that the reason for your problem is that you use a vector or matrix which was already defined before with a larger size or that for some reason an element with higher index was unintentionally assigned.
Re: Foor Loop
Attached now
Re: Foor Loop
Attached
Re: Foor Loop
Re: Foor Loop
@muser wrote:
Attached
No, still not.
Whats going on?
Do you try to attach a worksheet or a picture?
Re: Foor Loop
Work sheet. When I do a picture it says 20 000 words exceeded.
Re: Foor Loop
Not necessarily, as the picture below shows, but it sure would make more sense to leave the default ORIGIN=0 (or rather set it to 1, but sure not 4)
Re: Foor Loop
You can't simply copy and paste a picture here, you have to use the "Photos" icon to embed a picture in a post or you may add it like you did with the worksheet.
BTW, I would rather use
