Formatted output
Formatted output
Is there any way to format output data,( i.e. to place strings on either side of the data to format it correctly. Is there a function like the fprint fn in matlab that will give me more control over the format of my output data?
Formatted output
Not directly, as far as I know. You have to pass your strings and data to a user-function that you write and then use that function to write the data to file.
Formatted output
Try spec_io.zip at physics-23.umd.edu. Link is also available on 'Mathcad files around the world' page at Mathsoft's site as 'Mathcad Library for Spectral Analysis and Binary I/O'.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
