Fraction and Unit Fractions.
lvl107
20-Turquoise
Hello, Everyone.
Thanks in advance for the time and help.
Best Regards.
24-Ruby V
(To:lvl107)
Happy to be able to post again (although severely hampered by this "moderation" delay), here are some more solutions to your third task.
6 REPLIES 6
May be this is the "help":
Valery, try your method to find solutions for Loi's third problem 😉
24-Ruby V
(To:lvl107)
Guess you would have to write some routines to try "all" possibilities.
Using a generic brute force program I wrote some time ago I found some solutions for your first two problems.
Solutions with the smallest possible integers are
but if you allow bigger integers you get a lot more solutions. Below are the solutions for task 1 with integers from 1 to 200 and task to for the range 1 to 100.
As for the third problem, the denominator 2011 is a prime and so without amore intelligent algorithm we would have to try all numbers from 1 to 2011 at least. Probably there would be no solution found and we should try up to integer multiples of 2011. Trying all numbers from 1 to 2011 would mean we have to try 4^2011=5*10^29 times. Based on the timing with a smaller range this would take on my machine about 10^18 years!!
So problem 3 would require more thinking and less brute force.
Addendum: Here is one (of sure many) solution for your third problem, found by a different method, of course
Thats my second post after PTC introduced its "moderation" of all posts. The first was sent 6 hours ago and still is not open for public. Could image that if that kind of moderation stays, that I will go.
24-Ruby V
(To:lvl107)
lvl107
20-Turquoise
(To:lvl107)
Hello, again.
Best Regards.
24-Ruby V
(To:lvl107)
In the meantime you should know that Mathcads solve block can hardly be convinced to give integer solutions and you would have to write some program routines to get solutions - which is sometimes possible, sometimes not.
Why don't you attach a sheet to show what programs you have tried so far?
