From Series to CF - Theorem 2 - Euler .
lvl107
20-Turquoise
  Hello Everyone,
and the above is similar to :
     Is there a way to solve X0, X1, X2, X3  with a Program Function ?
     Thanks in advance for your time and help.
         Best Regards.
-MFra-
(To:lvl107)
If I understand correctly, you want this result.
Greetings
8 REPLIES 8
-MFra-
(To:lvl107)
Greetings
lvl107
20-Turquoise
(To:-MFra-)
Many thanks for your time and help, F.M. .  Could you attach .xmcd file for mathcad 14 ?
     Loi.
-MFra-
(To:lvl107)
The file is attached.
Bye
lvl107
20-Turquoise
(To:-MFra-)
  Many thanks for "the formula" of your program function, because :
-MFra-
(To:lvl107)
lvl107
20-Turquoise
(To:lvl107)
and :
-MFra-
(To:lvl107)
I would like to point out that the result has only symbolic meaning. To get a numerical result, you should do so:
lvl107
20-Turquoise
(To:lvl107)
Hello Everyone again,
and
   Solve, X[0, X[1, X[2, X[3 symbolically ?
   Thanks in advance.
