Function does not work with adding if statement
SOLVED
Newbie
Hi everybody:
I have got a problem with MathCad. When I define a function without If statement, everything is fine. However, as you can see from attached MathCad file, with adding if statement in my function, an error appers that "this value must be scalar"
Any idea why this happens. I have attached the file.
Thank you
Tags (2)
Re: Function does not work with adding if statement
Hossein Gholizadeh wrote:
Hi everybody:
See image below
Stuart
Hi everybody:
See image below
Stuart
Thank you so much. It works now
No problem.
Stuart
