Function of a function
Anousheh
6-Contributor
Please see the attached file. Help needed to do a function of a function and plot the graph.
Help will be appreciated.
Anousheh
14 REPLIES 14
LucMeekes
(To:Anousheh)
Something along these lines?
Anousheh
6-Contributor
(To:LucMeekes)
Hi Luc,
Thanks very much.
For some reason, the worksheet is not working.
and x=m+(1-m)x1 (you put it as x)
and the graph should be against x1.
and G(x1) is the correct one not G(x).
Could you please double check. I used the "substitute" symbolic operator and nothing happens. No error messages.
Anousheh
LucMeekes
(To:Anousheh)
Press F9 after opening the sheet. It doesn't calculate automatically.
In addition, for speeding up, you may want to set TOL:=0.001 at the top of the sheet.
And you can have the range of x as x:=0.001,0.002...1
The x or x1 doesn't matter. They're just parameters.
I guess you missed the fact that x depends on x1 and m
LucMeekes
(To:Werner_E)
No, I didn't,
that's why I substituted x with m+(1-m)*x.
The end result is the same, since x and x1 are not used simultaneously in any of the functions.
Yes, sorry, you a absolutely right.
I had't looked close enough to the pic
LucMeekes
(To:Werner_E)
The picture is so small...You're excused.
Anousheh
6-Contributor
(To:VladimirN)
Hi Vladimir,
Thank you so much. Would you please upload the file? I get G(x1) graph and F(x1,0.5) not showing up with no error message.
And one question: how the value of m (0.5) is incorporated into G(x1)?
Thanks again,
Anousheh
Here it is.
Anousheh
6-Contributor
(To:VladimirN)
Hi Vladimir,
Thanks again.
Would you please see the previous file again? Need G(x1) against x1 with different m= 0.5, 0.7 & 0.9.
Remember, x1=(x-m)/(1-m)
Thank you,
Anousheh
Here are my 2 cents:
MC15 worksheet attached.
BTW, I guess Lucs worksheet will work OK, if you turn on auto-calculation. Luc has it usually turned off and so you have to manually recalculate (Ctrl-F9) after every change.
Here is another way to deal with those nested functions:
Anousheh
6-Contributor
(To:Werner_E)
Hi Werner,
Thanks a lot.
Anousheh
