Function of function with units
SOLVED
Contributor
Dear members of the mathcad community,
I want to define a function within a function by considering the units of measurement.
The function looks like g(f(x))= f(x)*a where "a" is a parameter.
I know that there are other posts on the topic but unfortunately I could not solve the problem.
Attached you find an example of my calculation.
I would really appreciate your advice.
Thank-you very much.
Best regards.
Enrico
1 ACCEPTED SOLUTION
Highlighted
Re: Function of function with units
Hi Enrico
Here is your file all now working.
Cheers
Terry
6 REPLIES 6
 Maybe you forgot to attach your file?
Dear Luc,
Thank-you for pointing that out. There was a problem by the upload.
Now you find the attachment.
Best Regards
Can't see your file, as I don't have Mathcad 15. Maybe you could save as Mathcad 11 (.mcd)...
But this may be of help.
Highlighted
Hi Enrico
Cheers
Terry
Put the pressure function as the argument of the force:
F(p(a))
Wrinkle
There is also a small issue you should be aware of called "Vectorize".
This is applying a function to a column vector in an element by element fashion.
Look it up in help.
It does not apply to the equations in your sheet, but you should be made aware with different definitions it may be necessary.
Regards
Terry
