Function to dertermine quadrant
Re: Function to dertermine quadrant
Eden Mei wrote:
Mike,
That's great... It's not my area of expertise, so I had some trouble myself. That bobble I referred to was that I had posted an earlier version and only afterwards, realized that I had N and E backwards. That was followed by another moment of doubt when I thought the rotation wasn't working correctly.
I didn't mention it, but you can assign the find statement to a function, and your user's sheet can call the function after the values are entered, or, you could input coordinates into an array, and use an indexed array to retrieve the conversions.
TTFN
Eden,
It does get a little tricky with the rotation angle, at least it can be checked on AutoCAD to ensure correctness.
Cheers for the other recommendations, will have a look later today.
Mike
TTFN
Eden,
I am struggling assigning the find statement to a function. If you have the time would you create an example of each of your suggestions above?
Mike
MIke Armstrong wrote:
TTFN
Eden,
Mike
For completness I have attached a image of a function which will handle mutilple inputs and convert them into either Plant or OSGB.
Mike
Mike,
Sorry to have missed your posting, it's absurdly difficult to keep track of what's what in this forum. I'll try to take a look at it a later today.
TTFN,
Eden
