GUI in MathCAD?
Highlighted
GUI in MathCAD?
Hi:
I am new to the MathCAD environment. Is it possible to develop a GUI in MathCAD just like in MATLAB?
I dont want my end user to know the code, so, I would like to give a GUI through which he can access the components of the code. Is this possible in MathCAD? Let me know.
Neone
Highlighted
GUI in MathCAD?
One of the normal 'must have' benefits of MathCAD is the visibility of the real equations rather than impenetrable code.
The other technique is just to enter all the equations into an 'Area' (under the Insert menu), then close it and lock it with password protection (needs to be saved as V11 I think to overcome the readability of the XML format).
This will then present a 'blank' worksheet with only the locked are's bar across it.
You can call MathCAD from MatLAB (and Vice-versa) via the API. How to do it is buried in the help files and quicksheets. This can avoid showing the worksheet to the user.
Philip Oakley
Highlighted
GUI in MathCAD?
>format).
Save it in compressed XML (or Mathcad 11, but that may not save everything if you have used features not supported by MC11).
Richard
