Gappy Plots
GerritBarrere
Gappy Plots
I just installed Prime 2 and a plotting bug I've seen in Prime 1 is still there. Attached is a worksheet with some data points I grabbed from some simulation data to illustrate the point. Here is a screen shot of the worksheet:
Notice the missing connecting lines between several points in both plots. What is happening, and is there a workaround?
Gerrit
6 REPLIES 6
Just noticed that it seems to have to do with zero crossing. Offsetting the plots to one side or the other of the zero axis fixes the problem.
Gerrit Barrere wrote:
I just installed Prime 2 and a plotting bug I've seen in Prime 1 is still there...
And why you didn't report about this issue to PTC's technical support?
In Mathcad 15 M010:
and in Mathcad Prime 2.0, after converting the file from MC15:
I'll log this bug.
Mona
VladimirN
24-Ruby II
(To:mzeftel)
Mona,
Thanks. I hope this issue will be solved in a future service release of MP2.0.
VladimirN. wrote:
Mona,
It is fixed in P2 M010
