Generating matrices
BY_9768522
Generating matrices
I need to generate matrices however it must be with using the minimal number of operations I mean I can not create them manually I am adding a picture about it.
BY_9768522
(To:Werner_E)
Okay Sir thank you very much.
8 REPLIES 8
Not sure what you actually are looking for.
Your matrices are structured very differently and therefore require different approaches each. Basically you can use range variables for row and column indices or you can use a small program with loops (and possibly branches) for this. Here are two examples:
BY_9768522
(To:Werner_E)
BY_9768522
(To:Werner_E)
Sir I would like to contact with you if it is possible do you have facebook or any social media in order to contact with you?
You can ask your questions here in the forum - thats what its made for.
LucMeekes
23-Emerald I
(To:BY_9768522)
Here's another method:
BY_9768522
(To:LucMeekes)
Thanks a lot!
BY_9768522
(To:LucMeekes)
Hello sir I would like to contact with you about generating matrices, do you have email or another social account I would be appreciated
LucMeekes
23-Emerald I
(To:BY_9768522)
My social contact for this kind of matters is:
This forum.
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
