Geostrophic Wind.mcd
Highlighted
Participant
This program looks at the geostrophic wind, that is, the upper level winds in the earth's atmosphere whose direction parallels the pressure contours. We consider a very simple case to fix the essential ideas.
1 REPLY 1
Re: Geostrophic Wind.mcd
James,
How would it work if you would make the system unitless ?
To find the effects of different latitudes we make the following plot.
With a unitless system, you could then wrap your last graph around
a phere representing earth .
Nice work to read again !
jmG
