Hello, hope you are doing well,
I am trying to solve a system of 2 differential equations. However at the end of the solving block, i get the 'This value must be scalar' error. Any ideas?
Sincerely,
*I am using Mathcad 15.
Look up the help on Odesolve.
Your odesolve statement should look like:
Where t is the running variable, b is the end point and step is the (optional) step.
It worked. Thank you very much.
Cheers
