Global stiffness 6x6
SPRstructur
Dear all
please create automatically Global Stiffness 6x6? as pic and attachment mathcad below
Thank you
phearunstructur_0-1588913184653.pngphearunstructur_1-1588913466706.pngphearunstructur_2-1588913909764.pngphearunstructur_3-1588913992770.png
18 REPLIES 18
Messed about with this a long time ago.  Came to the conclusion that a professional software suite like SpaceGass, Microstran etc were better.  The scripting in the file chooses steel sections.
The file does all you asked.
Cheers
Terry
Dear
it can not open it
It is an old Mathcad file and is in a very old format *.mcd.
I have resaved as Mathcad 15 *.xmcd.
You need to convert Mathcad 15 *.xmcd to Prime *.mcdx with the supplied converter.
The converter is on the ribbon header at Input/Output | PTC Mathcad Worksheets | XMCD,MCD Converter.
Not sure how the converter will go I leave that to you.
Cheers
Terry
If you still have difficulties here is a pdf.
Hi  terryhendicott
honestly, I want to calculate stiffness of example 4 to understand dynamic lesson in attachment below
can you calculate Global stiffness as example below?
My mathcad sheet can calculate the global frame stiffness matrix for the plane frame as underlined below with the 3 degrees of freedom, horizontal, vertical, and rotation.
You would then need to make the adjustments to it as described in your example by assuming rigid diaphragm action of the floors and condensing vertical displacement.  The relevant mass matrix also needs to be assembled.  This is not done in my sheet.
I said before commercial software suites are available to undertake such analysis and most engineering companies have access to same.  The time it takes to get Mathcad working if paid at engineering charge out rates you pay for the commercial software suites.  Strand7 , SAP 2000, Ansys can do this type of time domain analysis.  If you are in an academic domain one of them is probably available to you.
Not to give up hope if you still want to use Mathcad 15 you should also check out the site http://www.dynamassist.com/
Cheers
Terry
Prime example for your frame.
For the calculation, the following additional files are required:
  • Asw_UB_Section.prn
  • UB_Desc.csv
Hi
Hi
Sorry about that.
Had to rename the prn file to txt to upload here.
You need to adjust that back.
Cheers
Terry
terryhendicott
what file use for?
I'm probably missing the point here, but is the attached along the lines of what you want?
Stuart
Hi
The submitter has asked two questions the second being how to get the global stiffness of a frame with 10 nodes and 12 members then condense that to the simplified form in his second example.   My answer shows how to get this global stiffness matrix.
Cheers
Terry
I thought it looked a little too simple! 🙂
Stuart
(I've only got Prime Express, so have to play within its limits, ie no programming or importing of mcd/xmcd files)
Many thank for trying find solutions for me
I have changed the file to Prime.
I have fixed the plotting of input, still have to fix plotting of results.
I have shown how to extract the horizontal deflections under horizontal force at each storey into a smaller matrix delta H.
I have shown how to use this sampled deflection matrix to get the required K.E
terryhendicott  great work 😍😍😍👍👍👍
Many thank
I have added some wording to make understanding the file easier.
Cheers
Terry
