How do you do the gradient of a column vector in Mathcad Prime 6 like I've done in Mathcad 15? See attached picture.
Here it is (create your function):
Don't forget to specify which version of Prime your worksheet is for (at least in the file name)!
Как прикажете, так и будет!
Done.
Stuart
