Graph lines shifted when printing
Participant
Good morning everyone,
I was trying to print my results and I noticed that the lines are shifted in the PDF (see image attached).
I tried several printers but always the same result.
Anyone knows how to fix this?
Thank you for helping,
F.
Tags (1)
Re: Graph lines shifted when printing
Guess you're using Prime 4 or 5...?
Is this similar to this issue:
https://community.ptc.com/t5/PTC-Mathcad/Printing-Bug-with-Plots-Prime-4-0/m-p/490071
Note that the bug was not solved for Prime 4 and therefore also not in Prime 5 (PTC logic).
Hi Luc,
Thank you for answering.
Yes I am using Mathcad 5.0 and yes the problem I have looks like the one you linked. Unfortunately that does not seems to be a solution yet. It worked fine for me at first and suddenly started doing this.
I'll log an IT request in the meanwhile.
Thanks!
@erbank wrote:
Hi Luc,
Thanks!
It's sad that PTC seems to be going backwards.
Since you are using Prime 5, have you tried using the new "chart component" as a work around?
