Graphing two variable 2
Thanks for the response.
I tried the function methode but was not able to get it to work.
Right after posting the message, I did find something that worked and attached the file.
i:0;1
w:1;100
R:matrix (5,6)
H[i,w:R[i*w
Plot H[0,w , H[1,w with w as x axis
Lee Snook
I have attached your file with the function form added. You first define the function with variable names, THEN put in the element identifications using vector components.
Physics: Common Sense made Obscure by Mathematics
