Hi
Good day. Hope you are having a nice day.
I am looking for if any of you have Mathcad Prime Template/sheet for solving a system of linear equation using Guass Elimination.
My actual problem is when I use solve block, every time I open the mathcad sheet, it doesn't update automatically only inside the solve block. I need to update solve block using "=" sign to find solution, then it works.
Hope to find a solutions.
Thanks and have a great day.
Jahangir Hossain
Attached to the message materials should help you:
Hi
Ya that documents helped me a lot especially the first one.
Jahangir Hossaon
You're welcome.
