HELP --
HELP --
I am creating a spreadsheet to find the mean, maximum and median of a set of numbers. I have no idea what this means. Could someone give me direction. Thank you.
HELP --
The definition of these terms should be in your textbook.
Maximum is the largest value
Minimum is the smallest value
Mean is sometimes referred to as the "average", which is the sum of all the numbers divided by how many numbers you summed.
TTFN,
Eden
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
