HEPL!! How to join many matrices in only One?
DavidVander
I wanna join or pass many matrices in only one....
Please look the attached image
its posible?
Your matrices should not be all named the same (k.1)
As you have a variable number of matrices (all with the same number of columns) you could store them in k[1, k[2, etc. and I mean vector/matrix indices here, not literal ones.
Now you could do it that way
8 REPLIES 8
Use the "stack" function.
it's not possible because the number of matrices to join is variable or dynamic......
Can you explain a little more?  I'm not sure what you mean.
gcevallos
6-Contributor
(To:MJG)
‌yes the stack function join many matrix, it is very useful to drive huge matrix
Hi.
You can pack matrices into a vector generating a MDA. Further you can acces each one with vector subscript.
Best regards.
Alvaro.
-MFra-
(To:DavidVander)
i have modified little bit the code but thank you so much.
Its solved
