Happy Pi Day
DanMarotta
2-Guest
Happy Pi Day
For all the mathematics fans out there, I wish you a Happy Pi Day (3/14); celebrating everyone's favorite mathematical constant
Here are some ways to celebrate >>
-Dan
33 REPLIES 33
LucMeekes
(To:DanMarotta)
Dan,
I have some problems with your statement, on mathematical and logic grounds.
- 3/14=0.2142857.... which is far away from 3.14159265....
- While it is easy to prove that there exist no uninteresting numbers, I doubt that you can prove that Pi is everyone's favourite mathematical constant.
RichardJ
(To:LucMeekes)
To me, e seems more natural
StuartBruff
23-Emerald II
(To:RichardJ)
Agreed. I'm a great exponent of eating πie off a log table made from the branches of trees with square roots (although some think this is rather radical, I think it's an integral part of the experience; it's what differentiates the true mathematician from the remainder)
RichardJ
(To:StuartBruff)
Yes, under the right circumstances a good πie can be an almost transcendental experience; the complex flavors can transport you to an imaginary domain. Nevertheless, whether or not π is 1’s favorite mathematical constant is a function of 1’s personal preferences. Clearly, in sum ways π is greater than e, but e has it’s base of supporters too.
Stuart, Richard,
Pi must be baked at the correct Degree or it will not achieve a Golden [brown] Ratio. I'm Maxed out on my mathematical play on words because I'm a Square.
Binomial for now,
Dan
Luc,
I must ask, do you have a personal favorite if it is not Pi?
LucMeekes
(To:DanMarotta)
Dan,
I always felt myself more intrigued by e.
Students in Russia know the second math constant e as 2.7 (all know it) + two times... Leo Tolstoy - a year of him born - 2.718281828.
lvl107
20-Turquoise
(To:ValeryOchkov)
Loi.
lvl107
20-Turquoise
(To:lvl107)
lvl107
20-Turquoise
(To:lvl107)
lvl107
20-Turquoise
(To:lvl107)
MikeArmstrong
(To:DanMarotta)
Happy pie day
Mike
Mike Armstrong wrote:
Happy pie day
Yes - three base math constants - p (p+Ctrl+G), i and e.
Mike,
Where's the vanilla ice cream?
MikeArmstrong
(To:DanMarotta)
Here you go - there goes the diet.....
Mike
I though a slice of pie, rather then the entire pie, with only two scoops of ice cream was the diet.
MikeArmstrong
(To:RichardJ)
Oh yer, good point. (As he heads back to the frezzer for the rest of the tub)
Mike
DanMarotta wrote:
Mike,
Look, enough of the food, already. Where's the beer? Being pi-eyed is the ultimate tribute to our e-ponymous number!
Happy pie day
Mike
Mike,
You have a Pi-snack - and here is the Pi-drinking.
The price of vodka in Soviet times long time was:
0.25 liters - 1 ruble 49 kopecks and 0.5 liters - 2 rubles 87 kopecks.
1.49^2.87=3.14
MikeArmstrong
(To:DanMarotta)
I do have one issue:- I can't believe anyone celebrates pie day like pancake day.
Mike
Happy pi/pie day:
VladimirN. wrote:
Happy pi/pie day:
More practical Pi-pie
More about Pi day and Pi Pie (Fractions).
Why I did not have Mathcad with gcd function in the first class of my school
See more about this problem here - http://communities.ptc.com/docs/DOC-3522
Happy Pi, e & i day.
The 6 of the Mathcad Clock has Pi, e & i - 3 base Math constants:
I'd like to remember Pi Day by making reference to one of your previous posts, Valery. (I could not think of a good reply to your remarks about Laplace transforms, so I did not post there.)
A circular slide rule is compact precisely because it wraps a linear slide rule around the circumference of a circle. The key to the transformation is pi.
Here is a snapshot of my own circular slide rule, a Sama and Etani "Model 90" (the diameter is 90 mm). Note that the "1" indicator on the C scale is lined up with pi on the D scale. So slide (rotate) the red indicator around to 9 on the C scale (for 90 mm) and read off 2.83 (i.e., 283 mm) from the D scale. Therefore, pi times the diameter 90mm is the circumference 283 mm.
Since there are 25.4 mm to an inch, we get 283/25.4 = 11.1 inches. To do this division on the circular rule, rotate the C scale until 2.54 is beneath 2.83 on the D scale. Then the C scale's "1" indicator points to 1.11 (11.1 inches) on the D scale. So our circular slide rule is equivalent to an 11-inch straight rule, at least for multiplication and division, since they use scales near the circumference of the rule.
Pi rules!
I was very sad when it has not received replies to a comment about the Laplace on the forum on Slide rule.
Variants:
  • I'm wrong
  • My colleagues on the forum do not understand this fine topic
I do think that you are right, and for my part, I did understand. But all I could think of to add to that discussion was that I thought your demonstration was very insightful. It occurred to me to attempt to prove your results using the definitions and properties of Laplace direct and inverse transforms, but I just don't have the time right now to go in that direction ...
When I was a student it was high art get mantissa and evaluate the order (power?) of the numbers on the slide rule ...
I have have have have numbers!
But now... With computer...
