Help with using Region class and SelectedRegion property...
Good afternoon all,
While perusing through the MathCAD "Developers Reference", I came across a few things I think may help me and I need somone to explain and show an example or two...
First of all, the Region class states that it represents a MathCAD region within a Worksheet object, and that it contains information relating to its location on the MathCAD sheet. What I would like to know about this is, 2 things:
1. Can I see an example of how to use the Region Class, and what the proper syntax is? I searched through the "Developers Reference" and online, but came up with nothing...
2. Can someone explain what the Region2 class is and why it is used?
Secondly, I have a question regarding the selected region property: What is it, How is it used, and what is proper syntax for using it?
Thanks in advance to all! And PLEASE help me!
Re: Help with using Region class and SelectedRegion property...
Hello!
Which version of Mathcad are you using?
Sorry, I am using MathCAD 15
The attached file contains some example scripted components. The file here:
Extra Components.mcd
Also contains an example. Search for "XML of a region".
