How can I express matrix?
SOLVED
Newbie
I want to express several column, not one column.
I searched for my book about mathcad and help in PTC mathcad. But I don't know. Could you help me?
I want to express to see easily because the row is 80
For example
current my picture-
[1]
[2]
[3]
[4]
[5]
my wanttng
[1 2 3 4 5 ]
[a b c d e ]
Re: How can I express matrix?
I am not sure. But I guess it is not my wanting.
I attached exfiles.
Thank you very much for your effort for me
25 REPLIES 25
Please upload your worksheet. From the picture it seems you have a single column matrix.
I am going to use 'range variable' to do my work because I saw book about mathcad that it suggest user to use 'range variable' for iteration
and I am accustome to use 'range variable compared to 'vector'.
I haven't got Prime and I'm not sure what you're trying to achieve, but if the intent is to show the last element of the vector, then can you simply drag the slider bar down the display until you reach the last element?
If you simply want a more compact display, and don't mind that it's shown as a matrix, then reshaping the vector into a matrix might help.
Stuart
Firstly it is your prerogative to use range variables if you so wish, but I would highly recommend using vectors.
I'm sorry, but I just don't see it.
You have defined three range variables, one having more elements than the other two and passed them as arguments to omega. I cannot see what you are trying to do. I suggest you try and explain a little better. Are the calculated results what you expected?
Stuart
Good idea Stuart, but reshape requires a vector.
Stuart
It's a shame that Mathcad Prime doesn't support a Mathcad 15 feature, namely the ability to enter a "range definition" (that is expressions of the form "a,b..c"). In M15, using my vec or seq functions, I can write, for example, x:= vec(0,0.1..1) and get back the vector [0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1], or even r:=0,0.1..1 , x:=vec(r) ... I think this last form might work, but I'm not sure.
Stuart
I guess he wants tables like the one below (maybe without the row and colum headers) - one for every value of mu and without any use of vectors.
Your crystal ball working again
Great assumption, but yet again we are guessing. Jinsuk Lee has not even responded to this thread, which he should have before creating a new one. http://communities.ptc.com/message/260284#260284
He hadn't resonded to other threads, too. He is jumping from one question to the other in quick succession, doesn't let us know if what we guess is what he needs and he consequently ignores our advice. Of course it could also be that Google Translate's Korean is so confusing he often can't follow our remarks.
Maybe its frustrating for both sides - a loose-loose situation, so to say.
