How can I fix the alignment of excel tables and pictures in Mathcad?
vishnut
When exports pdf file from Mathcad with pictures and tables, it is seen that some part of table or image will be in one page and other part in another page. But in actual Mathcad file, I am keeping the the pictures or tables only in one page itself. When go for print option to get the .pdf file, all the alignment goes misaligned.
It will be helpful if some suggestion can improve this situation.
Error case example follows,
8 REPLIES 8
May be the Ctrl+Enter help?
vishnut
(To:ValeryOchkov)
Still issue is there.
What version of Mathcad or Prime, and can you include file causing problem.
Cheers
This is Mathcad 15
I am so sorry I can't share the doc as it is confidential.
LucMeekes
(To:vishnut)
Can you duplicate the problem in a non-confidential file an share that?
vishnut
(To:LucMeekes)
Tried in few documents and failed to recreate the issue. But this issue is with few of my colleagues.
I think this is not file dependent
LucMeekes
(To:vishnut)
If you cannot recreate it, it will be hard to solve your problem.
VladimirN
24-Ruby II
(To:vishnut)
You can use the Case Logger tool on PTC's eSupport Portal to open Technical Support case: https://support.ptc.com/apps/case_logger_viewer/auth/ssl/log
