How can I have Celcius not Kelvin on the X-axes of Prime plot
SOLVED
Level 18
Help please - see the attach
Re: How can I have Celcius not Kilvin on the X-axes of Prime plot
Oviously it does not work the way it should (by simply chosing °C in the unit box) so one crude way is to do the conversion manually. Not very satisfying, I guess.
17 REPLIES 17
Thanks, Werner!
Same bag:
Re: How can I have Celcius not Kelvin on the X-axes of Prime plot
The Kelvin and Rankine scales are absolute--they both start at absolute zero and are therefore a ratio.  Centigrade (Celsius) and Fahrenheit scales have arbitrary (and different) zero reference points.  Mathcad has to use functions for that conversion.  If you look under units the the ribbon, you can select which units to plot with.
Not all is fine in Mathcad 15 too
Hi Fred!
Think we found a bug in Prime 5!
What you show was exactly what I tried first (and Valery sure did so, too) and it failed because we both used Prime 5.
It works OK in Prime 4 but throws an error in Prime 5!
So the bug was freshly introduced with Prime 5 (and we thought there would be no development of Prime any more ;-)
Maple has:
  1. Fahrenheit
  2. Celsius
  3. centigrade
  4. Reaumur
  5. Rankine
  6. Kelvin
But the 7 not the 6 is a fine number! Do you know 7-th temperature scale? I Know!
And the beat goes on . . . .
I guess with the new fancy graphing utility the built-in graphs could be farmed out to the interns.
First please explain the difference between 'Celsius' and 'centigrade' .
