How can I have mathcad to automatically import all my data when they are scattered ?
ptc-4735478
I have around 100 data file of exactly same format in excel
for example, cell A1:A10 is always the experimental condition
and cell A12:A1000 is always the raw data.
how can I have mathcad15 import all these data file instead of me repeating 100 times to import?
I want mathcad to read A1:A10, so that on my mathcad15 sheet it shows the experimental condition of the data
then I want mathcad to read A12:A1000 to have the raw data for analysis...
any one have a good idea to do it?
if it is easier to do in prime 2.0, i will use prime 2.0 too...
P.S. I dont know scriptable object.....
Hello Henry,
this MC15 sheet should do the trick
Cheers
Raiko
what if I want to read csv file instead of excel? It turns out I really have csv file and excel recognize them and is able to open them. But the formate is still in csv.
Is there a way to tell mathcad15 the range of rows to read in the csv? Or I have to first open each file in excel and "save as" in excel format? That would mean I have to open 100 files again.
Hi Henry,
of course you can read-in CSV files as well. In the FileList function set the file type extension from "*.xlsx" to "*.csv". Then you have to change the read-in procedure from reading excel files to csv files. For this purpose there are many read-in functions in MC15; see below.
Raiko
P.S.
I don't recommend for the time being MC Prime as I've encountered some issues with data import. MC15 works well.
