Hello I was wondering how I can use a solve block in order to find multiple answers.
I have attached a file instead of trying to ask the question in a confusing manner.
Thank you.
Here's one way ..
Stuart
Here's one way ..
Stuart
Thank you!
Dustin Braun wrote:
Thank you!
No problem.
Stuart
Here a slightly different approach not using the range variable i altogether. Instead the function call is vectorized.
Thank you for the help!
