How do a make a multi-line titleblock in Mathcad15?
igriffiths
1-Newbie
I'm trying to create a title block for a calculation document, but whenever I create my heading with multiple lines the lower lines don't show up in the print, only the top one. Has anyone encountered this issue before?
I've attached a little document showing the issue
1 ACCEPTED SOLUTION
LucMeekes
23-Emerald I
(To:igriffiths)
Change the top margin of your Page Setup (Menu: File => Page Setup) to a value larger than 12.7 mm/0.5 in and you'll see more of your header (and have less usable vertical space per page).
This is what you get at a top margin of 30 mm:
2 REPLIES 2
LucMeekes
23-Emerald I
(To:igriffiths)
Thanks Luc!
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
