I don;t know how to use the find statement in a solve block. I have tried everything but did not succeed.
How do you type it in to see a result of your variables.
Press F1 to get HELP,then search thte keys word "Find" to find what you want in the quicksheet
if he uses Mathcad 15 and below.
But also if he uses Prime, the advice to get familiar with the software first by using the built-in help and/or reading the manual applies equally.
The help for Prime is online, too, and the chapter needed is found here:
http://www.ptc.com/cs/help/mathcad_hc/prime2_hc/index.jspx?id=resourceid-131-0B8A8EDC&action=show
@rob kok: Feel free to come back with further questions if you get stuck and help doesn't help, but please be more concrete, state which version of the program you use and whenever possible attach your worksheet to show what you have tried and what you want to achieve.
May be this article will be interesting for You.
